This ^^^. No harm without pump. Check these guys out at Tin Indian. Get yourself an aluminum pulley system. It's adjustable. You can get yourself some longer hex head bolts to accommodate installation onto your balance/pulley system. Oh and a little blue loctite on bolt threads.
https://tinindianperformance.com/Tin...%20systems.htm
