Going through the iron heads you will spend close to new aluminum heads. I was planning on using the ported 6X heads on a 455 they came n but just tossing them on the flow bench and how heavy they were and the out of the box Edelbrock heads flowed more and weighed a lot less they are what went on that motor.
Even with the big chambers adding a stroker crank you can get either dish or mini domes for the CR you want.
