Rebuilt 400 HO suddenly runs rough
Car runs 1000x better! No stuttering or stalling accelerates great! Thanks so much for all the help! You guys rock!
The last annoying things are, when I come to a stop, it’s idling at 1200, but if I kick the throttle it goes back down to 800. It did not do this with the previous carb.
To Steve’s point: I drive it for about 20 miles (local). When I shut it down, it dieseled a little. And once it was warmed up, it took a bit more cranking to get it started. Should I move the timing to 38 (with vacuum advance disconnected)?
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
