Originally Posted by steve25
I bet that in your distributor the wire that runs under the breaker plate has totally dry rotted insulation with a lot of it missing off the wire, and when the plate move as you give the motor throttle the power to the points gets shorted out!
Thanks Steve. I popped off the cap to check the rotor, but maybe I should also pop off the rotor to check the breaker plate. I’ll take a photo and post it.
