9.2 with aluminum heads is great for boost especially if you are under 15 lbs. A little thicker cometic head gasket that you’ll be better off with if you turbo it anyway and you are high 8’s compression which is perfect for boost. My brother runs a 469 with an 88mm on 9.3 compression and e heads. The thicker cometic would give you the room for higher lift too and with the boost there isn’t a power problem anywhere and it would be super cool. Lol
