Thats ok,as it works as set up.The radio does have a fader control also but since there is no direct rear speaker connection to the radio,only connected to the 8 track,and since the power goes to the 8 track first then to the radio,that is proably why it operates this way for simplicity of wire harness assembly.The 8 track once a tape inserted automaticly cuts radio power and plays in both speakers since it is stereo.I am not sure but I suspect the red dot stereo radio has a modified harness so it has direct wire also to the rear speaker but?
