View Single Post
Old 09-17-2021, 03:47 AM
Kenth's Avatar
Kenth Kenth is offline
Originally Posted by NeighborsComplaint View Post
It's your pump not mine and I could care less. I assumed by the shape it was also a rotary vane type. You must not have read those instructions too closely because it clearly states it is a diaphragm style pump, not a rotary vane type ... so it can lift. If you understood the instructions, you would recognize mounting as close to the bottom of the tank as possible is the preferred method as it places less strain on the diaphragm. Good on you that it's still working but it wasn't intended as a basement sump pump.
I think you misunderstood something here.
Believe me, I can read an instruction and understand it.
Carter P4070 and P4594 are Carter Universal Rotary Vane Electric Fuel Pumps, they are NOT diaphragm style pump.
https://www.summitracing.com/search?...&keyword=p4070
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
