My Nash 5 speed is a 26 spline. Just order a 11" 26 spline clutch disc and you are good to go. Same deal with the output shaft yoke. I had a custom heavy duty driveshaft made with the good joints that matched up to the Ford 9" and the 400 Yoke on the trans output.
Only difference will be the rear axle he plans to run and the u-joint there.
