If you can get your hands on a big enough drill to power a 1/2” bit then just simply drill out each hole and then use a carbide burr to taper out the rocker stud side of the hole down to a depth of 3/4”.
You will not have to take much off once each hole is opened up to 1/2” inch.
I do stuff for reasons.
