If you lowered the stance, that would put the shaft closer to the top of the tunnel?
Possibly on a bounce the shaft is rubbing the top of the tunnel?
Also do you still have the emergency brake cable that goes under the shaft?
When you put the coil-overs on, is the rear end off center now?
