Check with Fabcraft or Brad Duerst but I think ot is that the 2.87 and below are one carrier width, then up to 3.23 is another but that may be 3.42, then above that is the final width. Fabcraft has several ratio gear sets made new but all of them only fit the last carrier width. Thus if all you have is a 2.87 or higher gear you are stuck with it. But Fabcraft can fix you up with whatever you need to change to whatever gear you need.
