View Single Post
Old 04-21-2024, 07:29 AM
Post 3 has the solution.
To drop it out let both headers dangle on there bolts as far as possible and loosen up the collectors bolts.
If you put anti-seize on at lease one side of your header gaskets then you should not have to replace them just tighten the bolts right back up.
Once out if you hacksaw off the unnecessary ears and casting ridge then at least the next if the trans needs to come out your use of curse words will be less.
