Congrats on the pickup! Since they’re pretty old heads, you may as well plunk down the hundred or so dollars on a set of springs that would be appropriate for your cam. Springs do wear out and loose tension. Proper spring setup is one of the most important keys to long life for your lifters, valves and seats.
