Back when I adjusted mine I used +/- .050 keepers and shims, to achieve desired spring pressures on the intake and exhaust. Gotta keep in mind distance to the valve stem seal on full open. I read .090 distance. Checkout PSI 1500 series springs. The website has a calculator for messing around with installed height to give you an example.
https://www.psisprings.com/
https://www.psisprings.com/calculate/
