View Single Post
  #54
Old 04-06-2024, 11:59 AM
JLMounce JLMounce is offline
Originally Posted by Jay S View Post
I can help you with picking valve springs, just need to know the IH of the springs. I don’t think you’re issue is with the valve springs though. It still sounds like your fuel pump won’t build pressure. It takes flow to build pressure, it doesn’t sound like it has enough flow at idle to build 60 psi. Probably gets worse as it tries to add fuel.
Yep, need know that too. The head were set up by KRE though, I can probably tell him which retainers it has just from the spring IH.
If the new fuel pump doesn't cure the issue, I'm going to purchase an IH micrometer and some checking springs. I can get that information from there.
-Jason
1969 Pontiac Firebird
