View Single Post
Old 03-28-2024, 08:58 AM
Formulas Formulas is offline
Something you can do to make the process a bit easier is to take your old pinion bearing use a sanding drum on the inside of the race where it goes on the pinion use the slip fit bearing to get a good pattern on your new gears establish a shim dimension then press the new bearing and shim on for final install
during the slip fit bearing use you use the yoke and new outer pinion bearing omit the crush sleeve for now and tighten down the pinion nut to get a few inch pounds of turning force on pinion ( everything seated well)
If your not at the table you're on the menu
The Following 2 Users Say Thank You to Formulas For This Useful Post:
