Check out my time slip…help me get faster!
Sooo here the combo……
70 4 bolt main block, 461 , compression 10.2, 340 Cfm eheads,, port matched northwind intake, camshaft: 248 intake 254 exhaust 620 gross lift 112 lobe separation. Vacuum pump
I am also running a Holley terminator x with a 1300 cfm throttle body…80lb injectors
Timing is set at 32-33 degrees at WOT
MT e-street R lowered to 14psi
Last night at the track ran…..11.68 at 117mph with a 1.77 60ft
Was looking for some tips to get faster with my combo….I probably need a cam swap is what im thinking? Thanks boys!
