Originally Posted by Jack Gifford
On the '58 in my GMC I used Chevy small-block 1.5 ratio full-roller rocker arms. However, it wasn't easy. I had to machine the stud stands to change the position and angle of the studs. This was only possible by using studs with 1/2-13 bottom threads. Pushrods are custom lengths. Not easy, but it's run great for ten years now.
I was wondering if that was an option. Unfortunately these heads already have screw in rocker studs. I do have another set of heads with the press in rocker studs, if it has to come that. Thanks for your input, it is an option!
Originally Posted by tom s
I ran a set of Comp 1.50 roller tip rockers,never tried full rollers.Tom
Thanks for your input! Were they Chevy rockers or Pontiac?
