Originally Posted by 461-69bird
Thanks Dave, do you think they would help or are needed?
This could help a bunch, the crankcase needs to get vacuum. Your current set up is not allowing enough area to pull from the top, especially with header evac. Your limited real estate up top is your crutch. Fix that and you may get better ring seal too.
