View Single Post
Old 01-13-2024, 05:15 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Regardless of the pump rating the problem with trying to use a mechanical pump to feed a big CID powerful engine in a pretty fast car is delivery to the pump.
I can tell you from actually doing it that 40gph or 120gph isn't going to much matter trying to feed it with 14' or so of 5/16" fuel line (the inside diameter of 3/8" line BEFORE you bend it). It is ALWAYS better to push the fuel vs pull on it. This certainly makes modern in-tank pump systems the way to go if and when the goals for your vehicle include a powerful engine and steps for the car to make HARD runs with good traction.......FWIW.....
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
