I'm having the same problems with RARE long branch and Pypes down tubes. My exhaust side leaks in almost the same spot. This past spring I had a local exhaust shop install custom exhaust system after the Pypes down tubes. Guess they couldn't get the angles right since they used a sealer when they installed the system. The sealer is
blown out now with the resultant leak. Thus is the second area exhaust shop that has done sub-standard work.
