Originally Posted by Vid
Between 3-5 lbs, probably closer to 3… [emoji3525]
It looks like the oil pump is by-passing most of your oil. With cold oil and the pump turning at 500 RPM you should have way more pressure than that. If it's not the pump by-passing oil then maybe the inner valley plug is not installed in the rear of the engine as already mentioned.
