Originally Posted by Dragncar
Milodon makes ductile iron for Pontiac,s in 3" and 3.25" mains, straight and splayed. You only have to cut .030 off a Mildon cap and they are ductile iron so the line bore has to be much easier for the machinist.
https://www.milodon.com/main-caps/main-caps.php
I’m trying to locate a set of these for 3” main 400 block. Anyone know of somewhere they might be available? Butler, Summit and Milodon do not have any in stock. Milodon says none will be available until end of February at the earliest.
Tom
1963 Lemans -428 +.030, SD Perf KRE heads, turbo 350, 9" Ford 3:90, 11.01@121
1956 Chieftain gasser, 461 stroked 400, SD Perf ported E-heads, turbo 400, Dana 3:70 10.40@125
