I've only done a couple of FAST EZ EFI installs, back before the Fi Tech and Holley stuff really took off.
I ditched all the in line fuel stuff and went straight for an in tank pump setup with my own fuel line system setup I build from scratch. I learned a long time ago the in line pump stuff is typically on borrowed time if you drive the car much at all, and like you found, a lot of it is really crappy small NPT fittings.
That was even back before Tanks Inc really took off with their EFI tanks and I had to retro fit in tank pumps with parts I got from Aeromotive.
https://youtu.be/XqEydRRRwqE
