Some thoughts, if you set the electric choke so its closed completely, then you will have that issue. Try setting it so its A quarter open. To be honest the chokes are very touchy, so I never use one. The ones that work with a little heat riser off the intake probably worked the best but I understand you have a electric one. I think you’re gonna find your better off not to even use a choke.
