Originally Posted by steve25
Are you using a cork type gasket or no?
If it only leaks on one side and since each head is the same, then how could it not be a gasket issue?
These heads are well known to not drain oil well back by the ( rear) last two valves.
If a gasket has dried out and shrunk then you will see a leak show up more when the motor is cold.
Pretty sure it's a thick cork gasket. Do you recommend something else? Valve covers are junky stamped chrome, too.
