Originally Posted by Sirrotica
There are 2 check balls in the 2 bbl Rochesters, one you already have located, the other goes into the bottom of the accelerator pump well. They are different diameters, and if you put the smaller one in the well it sticks in the casting. Sometimes it's nearly impossible to remove, it may be that someone has switched the balls and it is stuck in the casting.
In this parts diagram it would be #7:
I've seen this happen before, so I'm just throwing it out there that could be a possibility.
OK I have the large ball under the tiny spring and T holder. I have the smaller ball under the accelerator pump. Still no squirt AND if I tilt the carb slightly back towards the throttle plates, gas pours out the tiny venturi holes, which is my original reason for disassembly. I even doubled the gasket and tightened the hell out of the venturi.
