Originally Posted by wh33lman
This is exactly where I am at...
I have a Butler One-piece that is missing the rubber 3-prong section over the rear.
Consensus seems to be not to use the rubber 3-prong gasket, but use the thick cork gasket. I assume I should silicone the cork to the rear main cap first, then the ends where it meets the 1-piece gasket. My block has studs for the oil pan.
The last BOP one-piece gasket I bought had 5 prongs in the rear area - it was cut prongs off depending on pan style. Nevertheless, with the cork, yes, glue to cap first. Cliff R has a really good pic of how he sets it up - http://forums.maxperformanceinc.com/...95&postcount=6
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'69 LeMans Vert, 350, #47 heads: work in progress
Reason: Added link
