Corrected vs measured HP on dynos
So I know to compare from Houston to Denver to LA dyno results we need a standard correction factor. But the actual non corrected numbers are often lower-not "perfect air" -but that is actually probably closer to what the track conditions the car is going to be in running down the track so probably more real world numbers from my thinking.
