Later this afternoon, can ck fit on an original HM or HW coded 15x7 with a dinged up early style trim ring. The problem you're up against, the original squared off edge style trim rings weren't designed for the wider style center section of the '73+ 15" rally II's. Though i dont have any repro trim rings here, believe that same inner gap will be seen with the repro trim rings.
