Current engine combination
466 cu inch
10.8 to 1 compression
SD ported KRE heads 314cfm at .600 79 cc
Torker 2 plenum work by Derek Stewart port matched and runner work by Dave Bisschop
Wilson Tapered 1 inch spacer or open 1 inch
SD Performance "Old Faithful 2.0" hyd roller
.400/.391 lobes 235/245 dur
HS 1.65 rockers
Holley 950 HP or Prosystems 1000hp carb
Spectre Cowl air cleaner with 4 x 14 inch filter
Dougs 1 3/4 inch headers 3 inch full exhaust with X pipe and Ultraflow mufflers
3200 Continental 10 inch or 3800? Úcc 10 inch
8.5 10 bolt Eaton posi 3.73 gears Dutchman axles
