Originally Posted by HWYSTR455
My GTO has 1st generation AFX spindles, which has the specifically created/designed lower control arms by GW. The change to using a common, standard lower control arm was made to prevent potential mismatch of parts. I will be switching over soon.
HWY, out of curiosity, what springs are you running? Since the AFX has a built in drop, I would imagine you have to run stock height springs?
