I have a Honda 500 Rubicon for most of the snow plow duty. It has chains on all four tires. I also have blades for my 318 and 740X if needed. I've been moving a lot of snow with the loader as we got dumped on pretty hard late last week. You can only push snow so far until the piles are so big they thaw a bit then re-freeze as ice. The Yanmar is doing a fine job there as well. The chains really helped, nothing here is flat and right now there is about 2" of ice with about 12" of snow on top of it.......
