Originally Posted by Elarson
We had aluminum intake rockers on the nitro engine and they started to fatigue and break after awhile. Switched to steel and problem solved.
If aluminum rockers are an advantage in your BAE, just understand that they may need periodic replacement before you reach the fatigue limit.
Eric
There I a major benefit to going with the T&D rockers over the BAE steel ones...
It has nothing to do with the material.... it's a design issue...
BAE rockers don't oil on a cold start... we have to literally oil the rockers if the engine is cold...
Putt the covers and oil... t&d has figured it out... no need for cold oiling...
The BAE rockers work only off of splash..
Been that way for 25 years..
Recently changed but the t&d 's were only 6k for 2 sets...
