More timing at idle and at just off idle makes for more running cylinder pressure and it gets more or all of the burn done when it should , like in 72 to 74 degrees of Crank rotation, and this pumps out the Exh gasses better.
It's really just that simple!
The longer it takes for a given amount of fuel & air to burn the hotter the motor will run
