Originally Posted by johnta1
You need 2 fuel tanks?
I would use a 'Y' fitting instead of the 'T' fitting.
On the filter, is it after the pump or before?
The original tank was just over three gallons. We will redo the tank problem this winter. There is a "pill" in the fitting in the small tank to make sure both tanks empty at exactly the same time. Filter is after the pump
Glenn R. Lever
Rochester, New York 14617-2012
Web Site
http://www.leverfamilysite.com/
Front Engine Dragsters
http://www.frontenginedragsters.org/forum/
