According to what you posted in your first post, the piston is mounted correctly. Keep in mind the #1 cylinder is on the drivers bank, and the bearing tang notch and oil squirter hole need to face in towards the cam, not out towards the oil pan rail like you have pictured. The way you are holding the piston in the picture would be for if you put it in the passenger side.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
