If they are 5/64" rings you are good because they usually take around 35 ft. lbs.. 1/16" rings with standard tension oil rings is usually around 30, so I'd say you're good. If you have metric rings, then it's a bit tight. I've gotten them down into the 15-16 ft. lb. range.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
