If you have the motor out and the front clip off not that big a deal, unhook all the obvious stuff, body to frame bolts, emergency brake, gas lines, rear bumper has to be off, I would lift the rear first and put a 4x4 right above the rear tires and support on saw horses, do the same on the front under the fire wall, leave enough room to roll out the frame, I did mine years ago but used the lift to do all the work, take your time and have a few friends there to help. good luck jd grim BTDT 66 gto
