I did a test with a small piece of vinyl. Glad I did because the result was bad..
The bond is very strong between the vinyl and foam. The vinyl shrinks just a little bit when the glue dries. Problem is, all the small imperfections in the foam shows thru the vinyl.
Sucks.. I thought the foam didnt need much work, and the vinyl will just lay over it. Nope.
Thinking what I will do next. I can sand down the foam until its all flush with no bumps and imperfections. I'll keep you posted!
