Originally Posted by ho428
I think the only way to keep someone from busting your chops would be to run 4's 1/8 or 7's 1/4, with a single 4, N/A using Iron RA IV heads on a stock 400 block using an 068 cam.
Beyond that someone will find fault with the build.
It would depend on Rocker ratio and wether it has shaft mounted rockers weather i would be impressed with that combo or not.....
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
