Got some more done today. Installed the throttle cable and TV trans cable. I welded on a bracket to the throttle cable bracket to help support the throttle cable's 90* turn. There is still some play in the cable so shouldn't tug on it with engine movement. I solved the "too short" TV cable by getting some very stiff walled fuel hose (high nylon content?) that one end of the TV cable housing would slide tightly into and with a few hose clamps successfully extended the line casing. I had the pan off the transmission and adjusted the TV cable for the appropriate WOT position. I also installed a green 10-tooth speedo gear on the governor to get the speedo closer to accurate (still a ways off).
Then I installed the transmission dipstick tube, which ended up way taller than I expected. So I cut it down, which that part turned out good, then I "thought" I'd get fancy and when I cut the dipstick down I thought I'd cut the bottom off with the Fill hatch marking and then weld it to the bottom of the further trimmed dipstick so it'd read correctly. It was all good right up until the part where I welded it and the dipstick got super brittle. D'oh! So I need to pick up a new dipstick but when I modify it next time I'm going to overlap the lengths and drill two holes and rivet it. For now, the short stick will keep dust out of the tube =P And then I set the car on the ground to get a measurement for the driveshaft and by some miracle my old Skylark driveshaft is the EXACT size I needed. I picked up a new set of u-joints and will install it tomorrow which will be the real proof.
I started mocking up the exhaust as well. I still have to cut out the section of pipe where the X used to reside and do final fabricating of the collector to the rest of the system, but it's essentially in. I'm going to order up some 2.5" exhaust couplers before I go any further than I did today.
The throttle cable and TV cable hooked up and adjusted. I painted the bracket black after grinding the plating off the bracket for welding on the support. You can see one of the hose clamps and extension hose on the TV cable in the background.
The no bueno dipstick tube.
Much better. Even bolted to the bellhousing bolt.
The exhaust system. Here is the collector hanging down. The 400 engine had headers and the ball and socket coupler. I'm tempted to keep a 3-bolt flange there for quick removal. Haven't decided yet.
Looking down the car. It's up on jack stands so the axle is hanging low. You can see the hole from the X pipe.
From the side.
I put the car on the ground to measure the driveshaft, and took a picture from the rear.
Here is a picture of one of the motor mounts I ran bolts through. I used bumper bolts with the small head on the bottom and used all metal locking nuts on the top. I didn't run the nuts all the way down, they are about 1/16th of an inch from being seated to allow normal movement of the mount. I didn't have to do this to this mount since I didn't modify it, but by the time I 'thought' about it I had already drilled it. I cut half the safety catch off the other side to clear my exhaust collector, hence why I felt the need to do this.
And here are a couple shots of my saw blade trigger wheel in the car. Conveniently the bottom is protected by the cross member.
Just moving along.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
