Originally Posted by 1963Steve
Ok. So, is the "Fill?" label correct in the picture?
Yes. Stick your finger in the hole and see if it gets wet. If it does, you have enough lube for proper operation. If not, add until it runneth over.
Also, removing the fluid thru that hole is the least hassle (not the least messy, just the least HASSLE).
Good luck with it and welcome aboard!!
