I was working on getting my horn to work this past weekend so I was tracing those exact wires. The green one goes to your horns. The green wire runs to the front between the radiator and the nose of the car where it terminates to a double connector. From this double connector a wire runs to each of the horns. The black wire runs to the large connector that plugs into the firewall. This is the one closest to the drivers side fender. If you are looking at the connector form the engine side it is on the left side, second hole from the top. This wire then connects to the semi circle connector under the dash by the steering column, then continues through the steering column to your horn assembly in the steering wheel.
Hope this helps!
When I'm feeling down, I like to whistle. It makes the neighbor's dog that barks all the time run to the end of his chain and gag himself.
Advice for the day: If you have a lot of tension and you get a headache, do what it says on the aspirin bottle: "Take two aspirin," and "Keep away from children."
I don't always cross thread the bolt - but when I do I run that bitch in with an impact until it's tight!
