View Single Post
Old 02-10-2002, 01:34 PM
OPH I know you have had to played with this. Just got my 12 bolt back form having ends welded, backing plates opened up, etc. Went to mock up the rear discs and teh drivers side has been tweaked. One side of the caliper is 0.2" further away then the other side. Been trying to use a cresent wrench to bend it but it seems to cock it at an angle . Seems like the base of the bracket needs some bend and its too stout there. Also bending one side separate may not keep the spacing perfect.
Any suggestions? I figure being a floating caliper it can have a little mis match but I remeber having one caliper squeal in reverse because the caliper was tweaked.
