Question for the board
Posted this in the wrong section earlier…
Anyone run 4.350 Ross pistons, flat-tops, for Edelbrock heads, .990 pin bore and a 1.420 CH or maybe somewhere close to this? If you have the build sheet with the listed weights, can you share the ballpark average or a few of the individual weights? Ross will typically ship a set with a +/- 2 gram delta across the full set. Thank you. |
