grrr last bolt on upper belt cover stripped whats oversize bit for it?
Normally not an issue
but this one is tight and stripped so a #4 wont work. What works thats over sized? I think these are called truss head. |
4 Attachment(s)
If the #3 or #4 can't get it you'll likely need to cut a deep slot across it and tap/chisel it out.
Most times I come across parts engines any of the OE screws are toast. I have a stash of the Harley screws for replacements, while not exact, there near enough. |
Jeff I too have been saving the good old ones.
I dont remember these ever being off b4, Is this Harley part still available? |
Yes, these screws can still be had, mostly sub-dealers and epay.
ordered some stainless ones off Amazon that look about like the HD ones
I can send them back if they arent close enough 8 of them was about $10 |
head on the ones from Amazon are a tad smaller
will order a few HD ones to compare. |
2 Attachment(s)
They are also smaller in Diameter as well.
OK will do with these for now then
At least they are SS |
