KRE Dport head pushrod clearance
I have a set of as-cast KRE Dport heads. Do they have enough clearance in the pushrod slot to use 1.65 rockers? Thanks
It depends a whole lot on what the base circle diameter that your cam is and what the plunger height is in the lifters your running.
I have 2 sets of KRE dport heads on engines from SD Performance and the push-rod holes would have to be elongated to fit 1.65 rockers. You could give KRE a call and ask them about their heads. These heads usually have production numbers on them. Actually if you were to post a pic it may be obvious by the size of the push-rod hole. |
I have put 1 .65 ratio rockers on multiple sets of KRE D port heads over the years without any modifications. Never had any issues.
It seems counterproductive to have a pushrod hole that wouldn't support 1.65s or more than X lift. That seems like a 101 failure to me.
So, I don't believe that it wouldn't support 1.65 rockers and more than @.469 lift. Since there may be confusion, or conflicting info here, contacting the manufacturer would be the best option. . |
But Gary what length push rods are you running in all of these heads, stock 9.130”?
I did call the manufacturer and waiting for a reply. Thought I'd post here to see what other people's experiences were. Doing the math with a 1.65 rocker my lift will be .628 with the Comp cam currently in the engine.
I wish he still posted, here! |
My set would have been ok with 5/16 pushrod but I'm running 3/8 so needed a little work
Utilizes standard pushrod location for 5/16" pushrods.
Pushrod tubes are designed to accommodate 1.65 rockers without grinding on the heads. . |
