1982 Power Antennae
My mast broke and the motor continues to run. Pulling the radio fuse doesn't turn off the motor. What and where can I stop it until I get the chance to get to the unit itself ? Thanks.
It gets power in the black plug on the radio., or pull the fuse, or cur the battery cable, lol
I pulled ALL the wires from the radio. As soon as I connected the battery, the antennae motor started to run. It is getting power from somewhere else.
Is there a relay somewhere ? |
Power antenna relay is underneath the plastic panel below the dash map pocket. Remove the connector with the gray/green/white wires.
