Control arm ball joint
Ok, now that I beat that Fast ratio gearbox to death, got the new box today, got to get a different rag joint and see how that works.
Ok new issue, seems I have the stock lower mount and God knows what the top mount is, I have the moog upper and lower ball joints to install...………...seems like looking at the top mount......do I have to take that all apart to get that ball joint pressed out. Any get the upper mounts from umi……….at least they have the ball joint already installed. Rich |
seems like I missed something there.... like a pic
Vid link... This "klown" uses a hammer to remove it, and the press to put the new one in. I used the press for both in and out. https://www.youtube.com/watch?v=3EBDAgbJjjI |
Thanks Squid, I think I can manage that bottom one, was wondering if I could do that with the top ball joint...…...was hoping I didn't have to pull that upper arm out to do it.
Don't even know the brand of upper arm I have, supposed the ball joint was already on when they put in on the car. Worse part, getting new front springs...……..yeah I can see this going south real fast. Rich |
Was wondering if someone could recommend a good upper tubular control arm that you are using on a 66-67...….
Nothing against the stock one...…….im just use to seeing this type. Rich |
The top ball joint bolts in after you grind the rivet heads off the factory ones
64speed, thinking this tubular arm isn't factory...…...I don't see a rivet anywhere, its just a mess up there I cant see anything right.
Rich |
Oh I missed the part about non factory arms my bad
